Home > Technical (L322) > Rear light cluster bolt
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi,
The bolt holding the rear light cluster my 02 has corroded and then sheared. I am going to tap it and remove it. Will a standard M10 does as a replacement or is there some bespoke bolt I need to purchase to replace it with.
Post #525389 19th Aug 2019 1:12pm
From memory I think the bolt is M6. 10mm socket for the head.
I replaced all mine with stainless steel but any M6 bolt will suffice.
Post #525394 19th Aug 2019 1:30pm
Teaspoonasaurous
Thanks
Post #525399 19th Aug 2019 1:52pm
mjdronfield
Land Rover replaced the normal bolts with round heads needing a hex key to undo. There was a spate of folk stealing the light clusters....if you want the later type anyway....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #525415 19th Aug 2019 3:27pm
Teaspoonasaurous
Mine has one flat head and one hex on each side!
Post #525419 19th Aug 2019 3:59pm
Teaspoonasaurous
If anyone wants a working but damaged rear light complete with sheared bolt, this is yours for the cost of postage
Post #526135 26th Aug 2019 9:53am
Teaspoonasaurous
Post #526136 26th Aug 2019 9:54am
