Home > Technical (L322) > Heated/Cooled seats control knobs not illuminating
Bingo_123
is there any earth point under the seat or at the bottom of B pillar for the Seat heating/cooling modules ?
Post #638742 5th Aug 2022 8:19am
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
Enclosed photo shows issue
Post #641246 28th Aug 2022 6:01pm
DEEBEE(060)
DEEBEE(060) wrote:
All cleaned at front end, they weren't too bad but made no difference. Still no lights showing on controls
Post #641609 1st Sep 2022 2:02am
DEEBEE(060)
B1038-15 is IID error code. Front heater sensor General electrical failure circuit short to battery or open!
Post #641610 1st Sep 2022 2:05am
DEEBEE(060)
Do i have a missing module!
Post #643768 24th Sep 2022 2:33am
garyRR
Yes, I can confirm.
Someone has removed the heated/cooled seat module, which is why it's not working. All those spare plugs plug into a box like this underneath the plastic panel below the seat:
It's not the end of the world - I think used ones are around £40/$50 on ebay and last time I enquired with Land Rover main dealer, brand new are around £130/$150. As you've got a 2011-12 RR, I'd personally just go and buy a brand new module, because they can gain electric gremlins over time and the later cars are still worth good money Thumbs Up 2015 Range Rover Autobiography 4.4 SDV8
Post #643774 24th Sep 2022 8:26am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Hi everyone, been a while,
I have finally bottomed the issue, having checked many things over the years, I happened to remove the upper tailgate trim, and found the cable for the lh light had become nipped by one of the screws, causing a short, all repaired and hey presto all working 😁
Only taken 4 years🤦‍♂️
She's been laid up for a while, but mot Monday 😉
Thanks for suggestions, hopefully may help someone in the future 😉 Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #677250 4th Nov 2023 4:56pm
