Home > Maintenance & Mods (L322) > Adjusting access height |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
if you have the touchscreen year then any adjustment of the height settings will be global...it was only the pre 2005 touchscreens that could have individual/seperate height settings.. ... - .- -.
22nd Aug 2019 7:54am |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 |
On my 2005 with an ID tool you can set the access height right down to the bump stops, The access height is also same as the lower height on the turn knob as the press knob by the window buttons.
22nd Aug 2019 8:52am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
if he uses the button near the drivers window switch panel that lowers the whole car in a oner , then it will lift back up on its own as soon as he goes over 20mph ( ish ) no need to mess with settings ?? |
22nd Aug 2019 9:18pm |
