Home > Technical (L322) > L322 Retrofit Heated/Cooled seats 2011
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
Hi there, can any one help me with this. I have replaced my 2011 Heated seats with heated and cooled seats. I have change the dial / switch's and installed the heated cooled module; however the cabling has me baffled. Any advice would be most helpful.
Post #524600 13th Aug 2019 10:50am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
your missing the wiring looms to connect the control module. there should be 3 connectors for it. You will also need to modify the cars CCF file to tell it that it has them fitted. Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #524631 13th Aug 2019 2:35pm
Salter121
Thanks
Does anyone know the part number for the wiring loom I need?
Post #524648 13th Aug 2019 4:15pm
ianr63
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Did you ever get this sorted out ?
I purchased a TDV8 last year that is fitted with heated /cooled seats (heated seats have never worked) !
I have recently purchased a switch panel for the dash.
i would be interested in what other parts maybe required, i have not checked the loom yet for the switch panel or under the seat.
Regards Ian
Post #545299 27th Feb 2020 7:52am
