Home > Technical (L405) > After 405 console dimensions...
GGDR
Hi guys,
Would anyone be kind enough to measure thier 405 centre console?
- After mainly the inside width of the wood/piano insert.
- And length of the lowest flat section before it kicks up.
Thanks very much in advance.
. Cheers, Greg
Post #524599 13th Aug 2019 10:17am
Mr Tee
can do it at tea time, car's at home, mibbe a retired gent can assist before then ...
Post #524611 13th Aug 2019 12:54pm
GGDR
No rush, thank you !!
Bow down Bow down Bow down
. Cheers, Greg
Post #524612 13th Aug 2019 12:56pm
Mr Tee
so on the console, just the overall width? and from the front to just under the leather cover on the bend?
Post #524613 13th Aug 2019 1:06pm
GGDR
 Cheers, Greg
Post #524620 13th Aug 2019 1:51pm
i have to ask Greg, why?. ... - .- -.
Post #524625 13th Aug 2019 2:01pm
GGDR
I've got Madagascan veneer envy....
. Cheers, Greg
Post #524627 13th Aug 2019 2:04pm
nope , still in the dark.. ... - .- -.
Post #524628 13th Aug 2019 2:29pm
Baltic Blue
I think he has secretly got L405 envy. Rolling with laughter
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #524641 13th Aug 2019 3:27pm
GGDR
Just the console Mike!
. Cheers, Greg
Post #524644 13th Aug 2019 3:37pm
thats a start....then next month the wing mirrors..
it'll take a while though Greg.... Mr. Green ... - .- -.
Post #524655 13th Aug 2019 4:32pm
dolph34
Both wing mirrors next month Stan ??? , your very quick to spend other peoples money Rolling with laughter 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #524661 13th Aug 2019 4:54pm
Mr Tee
Width is 250mm length is roughly 275mm, the front arrow is actually under centre dash so measurements should be a rough guide mate .
Post #524789 14th Aug 2019 2:05pm
GGDR
You're a gent Mr Tee
Thank you!!!
. Cheers, Greg
Post #524792 14th Aug 2019 2:16pm
Mr Tee
Not a problem, don't go making anything bespoke before getting measurements yourself though !!
Post #524793 14th Aug 2019 2:25pm
