![]() | Home > In Car Electronics (L405) > Nav directions using voice control |
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
I’m guessing that on the main navigation screen where the EU map is displayed you have to change the country to be searched from U.K. to Ireland? Or maybe one can change the country to be searched by voice command? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi Peanutbob, the sat nav is changed to Eire and will look for addresses in the emerald isle if typed into the nav screen but the voice option will only search in the UK. When you try to put an address via the voice system it comes up on the dashboard display ^ United Kingdom' and will only search in the UK. I will have a look in the configuration files using my IID tool. Thanks for the input |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
when you say the address do you also say the country name at the end.... ... - .- -.
Hi Stan , i can't get that far, it seems to be using a predictive text type thing. Today i was trying to get to Dublin road , Portlaoise but once i got to dublin road, it would only give me options in the uk and i couldn't get past that part. 2015 4.4 AB
maybe say the country name first? ... - .- -.
Im back to collect daughter no.1 from a party later and will give it a go. When i use voice to attempt to enter an address it jas ' United Kingdom ' across the centre section of the TFT , between the dials. 2015 4.4 AB
according to he owners manual you can select voice commands for poi's, but no mention of addresses, unless i've missed it..
Thanks Stan , i did have a look at that , maybe in the configuration files , I will have look |
