Home > Duckworth Parts > Seat swab
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Seat swab
Good afternoon Dan
Is it possible to get replacement leather seat swab for a 2011/12 Parchment Semi-Aniline Seat? if so the price, please.
I have since found out the seat had been colour matched and after the 3 years of ownership, it is now showing a different colour?
Regards
Alex
Post #524104 8th Aug 2019 12:46pm
DrRob
Interested too for ivory Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524150 8th Aug 2019 4:58pm
duckworthparts
Site Sponsor
PM me reg numbers please chaps Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #524209 9th Aug 2019 9:06am
DrRob
Post #524211 9th Aug 2019 9:18am
Tinman
Post #524212 9th Aug 2019 9:19am
DrRob
Good to know they are still available but not cheap Whistle
I wonder how tricky they are to fit though Big Cry Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524213 9th Aug 2019 9:27am
GGDR
Pretty tricky DrRob
. Cheers, Greg
Post #524242 9th Aug 2019 1:24pm
GGDR
I found a way to do it without removing the seat.
Recommend doing the foam base at same time.
What price is the cover pls ?
. Cheers, Greg
Post #524244 9th Aug 2019 1:26pm
Tinman
Ok, how do you do it?
Post #524274 9th Aug 2019 5:24pm
GGDR
Ok so all instructions say to do this you need to remove seat....
And to remove seat you have to disconnect the airbag and to do that you need to disconnect the battery otherwise you will mess up the airbag ECU.
For me, without a garage or driveway meant I had to try to find a way of doing it with the seat in the car.
To get the squab out you need to remove the valance panel on the left of the seat (assuming we're talking about the drivers seat). This is hard against the console and you can't undo the torx screws. So you need clearance between the seat and the centre console.
So undoing the two rear main seat bolts, and the front left main seat bolt (nearest the centre console) allows you to carefully pivot rotate the whole seat on the front outboard bolt without stressing or pulling on the cable connector under the seat. Check check check as you go.
You can swing the back of the seat away form the centre console and get a very short torx driver in to remove the valance screws.
Swing seat back to normal position then carry on removing everything else you need to remove and eventually can unclip the seat squab cover and change it - or in my case change the foam.
I also think this seat-in-the-car method reduces the risk of damaging paintwork getting the seat in and out which is very heavy, aside of my issues of a street-parked car and no garage etc.
There is a detailed wiki write up for taking apart the seats too which helps with a lot of the details.
If you have heat/cool seats then check the ducting while you have it apart as mine had collapsed (wasn't me!) through age. The ducting on the base is made of foam layers which are additional to the main base foam. The whole lot works out quite expensive to replace. I replaced my foam but repaired the ducting which is on one of my posts if anyone needs.
On that same post you can also see how you don't necessarily need the hog ring pliers.
Good luck!
. Cheers, Greg
Post #524284 9th Aug 2019 6:47pm
Tinman
Thanks for the write GGD I too have done the seat heating/cooling with the seat still in place bit tricky but only after studying
the previous post I shall give it a go I do have a garage which will help to go and get cups of tea to calm the frustration Thumbs Up
Post #524285 9th Aug 2019 7:03pm
GGDR
No probs Tinman,
Getting to the seat back heat/cool unit is fine, the seat base heat/cool can only be removed by getting the cover and foam all off first..
Which was a right pain....
What was the price from Dan?
. Cheers, Greg
Post #524291 9th Aug 2019 7:24pm
GGDR
My seat base foam fix is here:
https://www.fullfatrr.com/forum/topic44946-135.html Page 10
This also has the bit about the hog rings - if you don't want to buy the special pliers.
. Cheers, Greg
Post #524292 9th Aug 2019 7:27pm
DrRob
Shade over 500 notes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524315 9th Aug 2019 9:13pm
Tinman
HI, GGD I have just read your other post on fixing the seat swab foam placing my order with Dan on Monday for the parts good news is that my heating/cooling works ok but will check out any deformation and follow your lead thanks for the link to your other post. Bow down
Post #524322 9th Aug 2019 10:05pm
