Home > In Car Electronics (L405) > Where's my satnav gone?
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Following a recent post regarding no voice control it's now apparent my satnav is not working either so I assume they're linked. All i get is a message saying satnav initialising but nothing happens. Any thoughts on this much appreciated.
Post #526598 30th Aug 2019 8:46pm
i would do a battery disconnection first ..hopefully this will reboot the systems.. ... - .- -.
Post #526599 30th Aug 2019 8:59pm
As Stan says... First thing to do sir Thumbs Up
Post #526609 30th Aug 2019 11:05pm
roberlar
Thanks for the replies. I assume disconnecting the battery will affect pretty much all current user settings including seat positions, vehicle setup etc. or is this held in some sort of memory ?
Post #526623 31st Aug 2019 7:52am
No sir, you will loose dash memory so, MPG etc + radar cruise settings etc but all seat memories are held in memoried ECU’s so won’t be affected...
Resetting the battery will put all of your ECU’s to sleep 💤 Then when you reconnect the battery this allow all of your ECU’s to wake up as they should!
ECU’s can go into “a distressed mode” (trying to start the car with a low battery, extreme heat or cold or just because it wants to!!!) resetting the battery is the only way to be sure it’s not just “one of those things” Before you start spending money on diagnostics etc etc...
Hope that helps 👍
Post #526626 31st Aug 2019 8:26am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
How unusual a JLR satnav getting lost, have you tried showing it a Tomtom. letters not necessarily in the right order
Post #526629 31st Aug 2019 8:38am
roberlar
Disconnected the negative battery terminal and left for a while before re-connecting......no luck. It seems the features not working are sat nav, voice command and stored cd's. Unless I've missed something all else appears ok Evil or Very Mad
Post #526649 31st Aug 2019 12:27pm
