Home > Maintenance & Mods (L322) > Activating service intervals? |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
No way to make the car tell me when it wants to be serviced? 2007 L322 3.6 TDV8 Stornoway |
30th Jul 2019 8:59am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
not sure this is possible..any thing via the search function? ... - .- -.
30th Jul 2019 9:13am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
Same problem on our 2006 TDV8.
30th Jul 2019 9:21am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Try a reset by using the service/ test menu... instrument pack... service interval reset ?.
30th Jul 2019 9:25am |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 |
My 07my tells me when it needs a service, so must be possible Remember:- amateurs built the ark
30th Jul 2019 11:38am |
I think my 2011 does, but I always reset it before it is due after doing a DIY service early.
30th Jul 2019 1:30pm |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
My 2012 does. I don't think it counted down though just popped up with 'Service Required' or similar. It hadn't been reset by the garage who did the full service (read oil change) when I bought it.
30th Jul 2019 1:43pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
AFAIK you can reset the service interval and when the service is due it pops up on the instrument panel but you can't access the information re time to run to next service.
30th Jul 2019 1:53pm |
I think you are both right..
30th Jul 2019 2:00pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
From 2005 you'll need something like AutoLogic to re-set the service due time. Not sure what year that stopped being relevant. Mine is a 2006 MY and cannot be re-set via secret menu's or similar.
30th Jul 2019 2:18pm |
You can also do it with the Gap iiD for the 2006 on. John
30th Jul 2019 2:46pm |
Attemptet an interval reset with the IID tool yesterday but just got "procedure failed" or similar. I'll try to do a print-screen when possible. 2007 L322 3.6 TDV8 Stornoway |
1st Nov 2019 10:05am |
2nd Nov 2019 7:06pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Did you have engine running? It has to be engine off but ignition on Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Nov 2019 7:08pm |
