![]() | Home > Technical (L405) > Loud fan noise when charging PHEV |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Most EV/hybrid have a fan running when charging (the battery and system does heat up when charging).
EdJ Member Since: 30 Jan 2015 Location: London Posts: 361 ![]() ![]() |
Not mentioned to dealer, but good to hear that this happens with other EVs. It all seems to work perfectly apart from this so I'm not concerned, but just wanted to check! Thanks for the reply. 2024 Range Rover P550e AB |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 789 ![]() ![]() ![]() |
Yes, one of the fans stays (loudly) on all the time while charging. |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 ![]() ![]() |
So energy is lost creating pointless heat and lost driving a fan to dissipate said heat but electric cars are better for the planet. letters not necessarily in the right order |
Exactly! |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 ![]() ![]() ![]() |
Mine makes the loud noise as described.
The remote climate is very effective isn't it. Much more so than it was in my previous V8 L405. Have they improved it, or is it related to the fact that the car is plugged into the mains when I switch it on? 2024 Range Rover P550e AB |
