![]() | Home > General (L405) > Purchasing approved 2016 ffrr 4.4 sdv8 advice |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
39k is way too far - like double the regular service interval.
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 353 ![]() ![]() ![]() |
There are more knowledgable folk on here then I, but I've just looked at the service printout for my 2016 4.4
Drksde Member Since: 22 Jul 2019 Location: Surrey Posts: 68 ![]() ![]() |
Thank you very much for the quick replies. As I thought the first year service was missed.
It’s kind of hard to believe it was missed - the car would be nagging you for a service, your warranty would be void etc - I just can’t see someone doing it.
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
Also, consider widening your choice of RR by not focusing on it,having RSE. A fire tablet or similar mounted on the headrest will give you many more entertainment options. MY23 D350 HSE
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Without proof that the car has been serviced at the correct intervals, you must assume that it hasn’t been. Service history on one of these is everything.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2663 ![]() ![]() |
I have 2 kids, had rse on old ones, now have iPad mounts. Way, way better. Can download stuff from Netflix/ sky etc. plus they can each have headphones on watching different stuff, you can thank me later |
Thank you for all the advice guys. I called land rover uk and they confirmed that the car doesn't meet its recommended servicing schedule and this can be a factor when they consider any claims I may have in my two years land rover approved warranty. I dont understand how they can then sell this car as an approved car from land rover with 2 years warranty when if you ask them directly they then tell you they may not honour the warranty!!!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
have a look at Cam Tech Craig's 405 post.
I have 2 different mounts, one was one from halfords, works with a magnetic pad you stick on the back of the ipad, works really well, simply attached to the headrest brackets. The other was something I stumbled across whilst perusing the ebay one evening, allegedly made from carbon fibre, which attaches to a headrest post and the ipad sits in a case which screws into the mount, has 2 knuckle joints so can rotate at whatever angle you want, I used to use this one on its own as both of them could easily see whats on , but it did my nut in with peppa fecking pig in my ear plus splitting a signal via Bluetooth for 2 hedphones is not an easy task so I went for another mount, which saves so much hassle . I've never enjoyed long journeys as much |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
With regard to the missing service history it would be unusual for someone spending £100k plus for a car to skimp on servicing.
Just an update, the dealership has returned my deposit, but initially didn't want to. So back to my search. Will take on board about RSE, however it's still hard to find the exact spec, looking for a dark coloured 4.4 autobiography with deployable steps privacy glass and 22 inch alloys from an approved scheme.
I listened to both, then waited until I found one with the signature. Once I heard it, it was a must have option for me. I even gave up deployable steps for it (and I'm only ickle |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1451 ![]() ![]() |
As you are looking for something specific (dark 4.4AB etc) then I wouldn't get too hung up on the 22 inch alloys as they will be easier to source later. Good luck with the search, it'll be worth it in the end ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
