Home > Technical (L405) > Occasional issue 4.4 sdv8
dolph34
Hi all , sometimes after restarting my 2015 4.4 sdv8 is will surge between 500 and 1000 revs and sometimes cut out , i restart, and it might happen again and then its perfect , no faults shown on IID , any ideas, booked into MD but just wondered if anyone had this issue. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #522547 23rd Jul 2019 11:26am
Bill
Yup
Within the first 1/2 mile the car would over rev 2-3000 revs . I never had a cut out . SDV8 4.4
I just slow or even halt / neutral, and all returned to normal. I assumed it was me !
Eventually I had a proper fault _ yellow light etc
Throttle body stuck, shutter didn’t spring back, Well sooted up. ( part LR020694)
Really easy for your engineer to get to & look at.
Engineer also updated the software for the car 2016
Since then no further experience,
Let me know how you get on and if comparable . Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #522549 23rd Jul 2019 11:58am
dolph34
Thanks for the quick response Bill , mine seems a bit different , on start up engine 'hunts' between 500 - 950 revs , like it not getting enough fuel. It sometimes cuts out but starts up perfectly and drives 100%. This has only happened 3 times in the last two months. I will give tell the MD your experience as it may be similar. Thanks again,
regards John. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #522551 23rd Jul 2019 12:06pm
clogged up fuel filter?
splits in hoses, maf sensor needing a clean...
high heels getting stuck on accelerator.. ... - .- -.
Post #522556 23rd Jul 2019 12:44pm
dolph34
Lol thanks Stan , just had MD sevice so hopefully not filter but who knows , starts from cold perfect and no faults. Just tried reading fuel pressure with IIDTOOL an all seems ok. Best to hand to the ' experts ' 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #522558 23rd Jul 2019 12:46pm
