Home > Maintenance & Mods (L322) > Should pdc engage automatically?
Danwilderspin
On my old 4.4 it was pretty straight forward pop he in reverse all the pdc sensors come alive.
Now on my 4.2 I have to press the pdc button then they all work any idea how i can make it as above? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #521522 11th Jul 2019 9:02pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
At a guess it probably needs the auto setting turning on in the ccf. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #521554 12th Jul 2019 10:27am
stu1
It's auto on mine - put it in reverse and they come on.
HTH Thumbs Up
Post #521589 12th Jul 2019 4:02pm
Strider
+1 Thumbs Up
Post #521600 12th Jul 2019 6:51pm
Danwilderspin
What’s the ccf? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #521615 12th Jul 2019 9:18pm
stu1
Car Configuration File. This is editable with, for example, an IIDTool.
Post #521621 12th Jul 2019 10:21pm
Grofus
Car Configuration File, accessed with an IiD tool Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #521622 12th Jul 2019 10:21pm
stu1
SNAP! Smile
Post #521623 12th Jul 2019 10:22pm
Grofus
Spooky, answered at the same tine 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #521624 12th Jul 2019 10:23pm
They should turn on automatically Dan...
Do your reverse lights work? Reverse Cam?
Post #521625 12th Jul 2019 10:27pm
Danwilderspin
Hi Craig
Not checked the light but the cam does for sure... do the modules need coding as the old Bmw ones which I believe fit only go for a tenner on the bay so might just swap it out for ease Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #521631 13th Jul 2019 5:31am
Danwilderspin
Censored well I swapped between the two cars and the old one still works the same and the new one still need to be manually pressed --- looks like the ccd file it is - can this be done with the ids software? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #530312 8th Oct 2019 1:59pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Not sure that it can Dan -- I have the IID Pro tool and can do that for you Smile -- PM me Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #530313 8th Oct 2019 2:22pm
Danwilderspin
Hi all
Back on this - I wanted something to clear my adaptations as I have done a lot of work on the car. I thought id treat myself to a non bt iid tool. Arrived today off a member (thanks) and updated registered etc. However... there doesn't seem to scan a PDC module? and there is no options for it on the ccf? I'm mega confused now... any help would be appreciated....
Also while on the iid tool - if I want to update the PCM through the fast lane service do I get a new build for the iid tool where say update will be under Ecu flash?
cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #531235 17th Oct 2019 2:19pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
On my old Discovery 3 the front sensors automatically came on when you dropped down to parking speeds. Didn't need to press the button.
My 2008 RR doesn't do the and the front sensors only come on when the button is pressed. Is it possible to change this?
Post #531292 18th Oct 2019 7:07am
