![]() | Home > Technical (L322) > Gearbox issue still present? |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 ![]() ![]() ![]() |
Which engine/gearbox is it?
Muzzychris Member Since: 03 Jul 2016 Location: County Durham Posts: 27 ![]() ![]() |
Sorry I forgot to put it. It’s a 2004 BMW 4.4 V8. I searched about that as it seems more common on the X5s. People seem to say you can’t reset the adaptations on an old box though, then surely that means the only option is a new box? Thanks again. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1260 ![]() ![]() ![]() |
I seem to recall that there have been some threads about this, particularly RRPhil, its a 1st to second gear issue I think.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 993 ![]() ![]() |
It’s tricky to determine if this is a control issue or a mechanical/hydraulic fault. One option: I could supply you with a fully rebuilt and tested valve body assembly for £300 +VAT +postage to try. If this didn’t fix the issue you could return it within a fortnight for a full refund (except the postage charge) and you would then know that you have an issue with the running gear which requires a transmission rebuild to fix. Even if it did fix the issue, you still have the option to return it if you fancied having a go at rebuilding your own valve body assembly, knowing that’s where the problem lay.
That’s great info thanks Phil,. To be honest I’m struggling to find somewhere round here that knows anything about these 4.4 gearboxes only the TD6. That would be beyond my abilities to try.
Unfortunately, I only work on the transmissions themselves as I don’t have the facilities to work on vehicles.
