Home > Maintenance & Mods (L322) > Can someone tell me how I change p/n 4628214 ?
Danwilderspin
Hi All,
In my other long post with multiple points mentioned at the bottom that this part number has failed its the intercooler duct/bellows (4628214)
What I don't understand it how to change - the two. nuts and bolt are removed and its loose but as the bolt studs are so long I cannot them out trough the holes?
Would really appreciate some feedback.
Many thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519105 20th Jun 2019 2:59pm
Danwilderspin
Surely someone has done this at least once on here Sad really stuck now - I could probably bust this one out but then the new one id need to knock the studs about and use bolts surely there’s a way Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519152 20th Jun 2019 8:37pm
forum search or WM?? ... - .- -.
Post #519160 20th Jun 2019 9:07pm
Danwilderspin
Hi Stan - forum search yields no results nor does just the part no.
Looked at the wm and it doesn’t mention changing it out specifically it just says you should change them when working on the coolers so not much help again.. cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519171 20th Jun 2019 10:10pm
Danwilderspin
Found this on the jag forum
it's a cheap and simple job to replace them. Remove the air ducting above that elbow, the elbow itself just has 4 bolts holding it to the s/c, remove them and you get enough movement to get the seals out. no need to remove the water pipes or anything. I was advised to replace the rubber gasket between the s/c and elbow, so I got one and used it, but TBH the existing one was totally fine. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519172 20th Jun 2019 10:15pm
