Home > Technical (L322) > Towing electrics
Dizzy Dee
kooky_guy wrote:
Brian Considine wrote:
In answer to the OP & kooky the PF Jones Kit is "plug & play" - fitted one to my 03 plate L322.
They do single x 7-pin, double x 7-pin & 13-pin variants.
Thanks, I was just trying to work out which type of socket would be best to get. Sounds like the PF Jones kits will be ok then. The genuine LR ones are MUCH more expensive. Do they do anything the PF Jones ones don't?
Personally, I would go for the 13 pin, the connections are alot more reliable IMHO and you can always use it as a charging point if your battery ever goes flat.
ATB
DD
Post #543769 12th Feb 2020 9:39pm
Brian Considine
kooky_guy wrote:
The PFJones one should be plug and play too shouldn't it?
It certain was for my L322 (BMW). 2003 Range Rover Vogue TD6
Post #543811 13th Feb 2020 2:20pm
