![]() | Home > In Car Electronics (L405) > Losing 2 mins of time per month - Anyone Know Why? |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
How fast are you driving? are you close to the speed of light? relativity could be your problem. |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
its the cost of the crystal that regulates the frequency oscillations of the clock.....cheap crystals lose a few mins in so many months, expensive crystal dont.. ... - .- -.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Yes. Your car only cost £100,000 so Land Rover use cheap crystals.........🤔
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
Mine does exactly the same ![]() |
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 ![]() ![]() ![]() |
The dilithium crystals? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
I seem to lose time when I use a crystal too.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
I am more of a brandy man myself, but the effect is the same 💤💤💤 |
there's also a theory that if you use your sat nav a couple of times a month then the gps updates the clock to the correct time.. ... - .- -.
That’s easy to prove right or wrong.
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Just been out to my car to try that , it doesn't work they are not linked .I did not think they were we don't have a BMW system which is linked and even changes the clock when you go into Europe ! My 2015 car also runs slow 2 mins every month . The fuel gauge never reads full even when you carefully brim it , I think that could be corrected in the software ? |
Judging by how out of date our sat-nav's are, using GPS to update the clock would take us back to 1983! ![]() Mike |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1104 ![]() ![]() |
They all do that sir, the only thing they loose faster than time is value. letters not necessarily in the right order |
