Home > My Range Rover > Wahoo, got my fatty today
RobWheatley
Well Led sidelight, high beam and cornering bulbs installed today, look great but now the xenon bulbs look yellow, 2 new 6000k d3s bulb now being delivered tomorrow along with 501 led's for the interior lights.
Need another 2 H8 led's for the fogs and make the relay/resistor units to stop the strobing.
Whilst in Aldi yesterday I bought a solar battery 'charger' only 6w but as I dont drive her every day it can only help.
Also got a DAB radio unit that takes a microSD card, it can transmit on fm or (as I have used) connect via a 3.5 mm jack cable. The aerial lead is a bit short but once I route it through the centre console it will be just long enough. Fitted that in the centre cubby tonight, works quite well and turns off with the ignition. Need to install another aux in socket into the chubby so the lead doesn't have to run to the back the trim that was missing from the front of the roof has arrived, now need to paint it black.
After having her for a week, so far the only faults I can find are:
PDC doesn't work.
1 key is temperamental.
Access button doesn't work ( will go up and down on the main suspension buttons)
DVD remote doesn't work (probably me doing something wrong)
Battery is not 100% (wouldn't start after trying the FBH and is only 12.4v after a charge)
Apparently it had tpm from the factory.
To do/get list:
Battery.
Service.
Find a towbar.
Get a roof rail/rack set (yes yes I know)
Mirror covers with indicator repeaters.
IID BT.
Halo's
Redo the privacy tints (has a few marks)
I'm sure I will have more as the weeks go by. 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #519269 21st Jun 2019 10:58pm
