Home > Maintenance & Mods (L322) > Hesitant
mudknight
2003 Range Rover Vogue Td6 Java Black
Hesitant
I tow a trailer moving cars all day , when the engine is working hard going up a hill it suddenly hesitates, as if I've taken my foot off the gas a little. It doesn't stop or misfire , after about 4 to five seconds it kicks back in again . It also happens when not towing too but not as noticeable.
Post #517696 7th Jun 2019 1:50pm
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
Hi there,
I had the exact same problem with my TD6. Turns out the Intercooler hose that goes from the Turbo to the Intercooler had come loose (due to a rusted clip). Very easy to change if you have the Fan shroud and viscous fan already removed. You should be able to get a visual look at it pretty easily, just make sure it's nice and snug and flush with the intercooler. Mine was loose and about 2 centimetres from the intercooler.
Post #517703 7th Jun 2019 3:17pm
MarshallW11
If that ends up being your problem too let me know and I can send you some pictures/parts that fixed it for me
Post #517704 7th Jun 2019 3:21pm
mudknight
Soon as it stops raining I'll get out there and have a look , cheers .
Post #517757 8th Jun 2019 8:00am
mudknight
I've had a look and it's the top intercooler hose split , oil has covered powered steering resivior and fuel filter and all those areas , ordered a new one so hopefully that'll cure the hesitation .
Post #517900 9th Jun 2019 5:53pm
