Home > Technical (L322) > EGR plate, bottom end
Deicist
Hi,
I recently fitted the excellent EGR blanking kit from ebay, but when fitting the bottom plates I stupidly used the old bolts. During refitting I realised that the reason the plates are supplied with allan key type bolts rather than the Torq type originals is so you can't overtorque the bolt when refitting and shear the head off..... which I promptly did. So now one of the bottom plates is basically held on with one bolt.
What problems can this cause? If there's a leak there, would it reduce boost pressure to the turbo on that side for example or is the plate just there to stop crap dropping into the engine?
I can probably drill the bolt with a left handed drill bit and get it out that way, just wary of drilling into my engine if it's not actually causing a problem.
Post #517507 5th Jun 2019 1:45pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
That is the exit port from the Egr valve which you should have mapped out anyway.
Its under no pressure so one bolt should be fine.
If you want to be sure run a bead of gasket sealant around it. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #517631 6th Jun 2019 6:41pm
