Home > Technical (L322) > Heated cooled seats
iainvr4
2004 Range Rover Vogue Td6 Java Black
Heated cooled seats
I know this isn’t a new topic but does anyone have the test procedures wiring, resistances etc for the peltier unit so I can test the resister and unit? Mine is coming on when cold but cuts off when warm?
Thanks
Post #517152 1st Jun 2019 4:15pm
GGDR
Start here, a big read:
https://www.fullfatrr.com/forum/topic44946-150.html
Also worth a look:
https://www.fullfatrr.com/forum/topic49757.html
This is a failed attempt by me to use Peltier from a Ford Mustang with looked identical and I fitted it back into the LR housing but it (eventually) also cut on after a few mins on heat. This being a new peltier, I think the control unit must be very fussy with values.
Lastly, there is a decent section with all the specs, test procedures etc in the WM, PM Stan and with a site donation you can get it.
It's one to crack because these go too easily and at £225 a unit, bear in mind two units per seat, there must be a cheater fix. Let us know please!
. Cheers, Greg
Post #517156 1st Jun 2019 5:16pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
IT`s more like your plastic ducting has a crack across it which is a common fault, that gives you the working on cold but not warm?
Post #517157 1st Jun 2019 5:16pm
GGDR
Ah yes, mechanical failure is the first thing to go.
On the seat back unit as Tinman says the ducting can crack. I fixed up my cracked ducting but the peltier would not heat so I had to replace it.
On the seat bottom, there is a soft ducting system and this can go too. I also fixed my soft ducting but still had to replace the peltier unit.
. Cheers, Greg
Post #517158 1st Jun 2019 5:21pm
iainvr4
Hi thanks I’ve stripped it and checked the ducting and it’s ok mind you I only checked the one the back of the seat
Post #517159 1st Jun 2019 5:21pm
GGDR
The seat base unit is annoying to get to because to get the one last screw that holds it in, you need to take the whole seat base cover, cushion, sides everything off.
I did manage to do this without removing the seat though.
I must say, I was enjoying the cooling today with this fine weather!
. Cheers, Greg
Post #517160 1st Jun 2019 5:24pm
