Home > Maintenance & Mods (L322) > Changing from 2 x 7 pin to one 13 pin Towbar Electrics |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
My 2011 Vogue came with a Wesfalia towbar with removable hook and two x 7 pin plugs. My caravan has a 13 pin plug, and although I could use an adapter, I would prefer to fit a 13 pin wiring loom, and these are available here:
27th May 2019 6:24pm |
kevshore Member Since: 21 Dec 2018 Location: ne lincs Posts: 11 |
That should work. Converted a couple of these for customers. PF Jones are spot on. |
27th May 2019 7:41pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
2011 is plug and play I thought with no CCF changes needed. I might be wrong....
5th Jun 2019 7:41pm |
The 2011 has no trailer module, but when I checked with GAP, they told me to set these three. 2011 Vogue TDV8 4.4
6th Jun 2019 4:32pm |
Gap tell me that these are the same changes set by the LR official diagnostics. They don't know exactly what affect they have. 2011 Vogue TDV8 4.4
7th Jun 2019 8:26am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Our 59 plate TDV8 had two 7 pins. I just fitted a 13 pin and rewired it. Altered the CCF in IID and it all works a treat. Just cost me £8 for the 13 pin plug. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th Jun 2019 6:27pm |
I guess you didn't replace the whole wiring loom, just the plug. Good cheap job. the complete loom costs £80 2011 Vogue TDV8 4.4
7th Jun 2019 6:55pm |
No. I was going to fit that loom that you had, but I’d converted my previous TD6 and I still had the wiring diagram so did this instead. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th Jun 2019 6:58pm |
