Home > Technical (L322) > Steering column fault |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 |
Hi, my TD6 has recently developed a loud clicking noise from dash area when I unlock it, and today the steering wheel adjustment has stopped going up and down (back and forth is fine) and is stuck quite low, would I be right guessing the motor drive has gone? Can still hear a whirring when I operate adjuster! I have a V8 Vogue that I am just about to sell, so could temporarily borrow any bits to try if needed. Also steering has seemed a bit notchy when cold recently, V8 is much smoother! Any advice gratefully received. Thanks in advance. |
27th May 2019 3:02pm |
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 |
On my TD6, the white plastic attachment that holds the motor in place had snapped. Haven't gotten around to fixing it yet, but if you remove the footwell cover you can get an easy look up in there to see if something jumps out at you. |
27th May 2019 4:48pm |
Lovely, will do, thx for the reply mate |
27th May 2019 4:57pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Have a look here. Might help https://www.rangerovers.net/repairdetails/steering/tilt3.html John
27th May 2019 5:51pm |
Thanks, that's excellent mate, will pull it apart tomorrow... |
27th May 2019 7:31pm |
