Home > Technical (L322) > Rear parking sensors
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Do any of you knowledgable people out there know how to turn parking sensor volume up using the iid tool please ?
I've plugged it in, but can't see how to turn volume up.
Post #516532 26th May 2019 10:35am
you cant on yours....i extended the speaker to just below the right hand side of thd drivers seat...
Post #516575 26th May 2019 4:23pm
Ahem you can Stan... Whistle
Turn off radio and Put your car into reverse and get close enough to make the sensors activate, then simply turn the volume up/down on the steering wheel buttons and voila, the volume will now be set higher or lower as required Thumbs Up
Post #516577 26th May 2019 4:45pm
tried that with my 2012 and that method didnt work....hope it works for you tomo..
nice tip craig.. Thumbs Up
Post #516581 26th May 2019 5:07pm
Should work on yours Stan...
Try it with the stereo on? Should be able to turn it up & down as you would with bluetooth sir Thumbs Up
Post #516584 26th May 2019 5:13pm
Tomo676
Thanks for the reply, will give it a go and get back to you.
Post #516629 27th May 2019 5:20am
Tomo676
Well I've just tried it Craig and unfortunately it doesn't work on my 2010 Fatty.
Post #516641 27th May 2019 8:44am
charlesj
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Did anyone get any joy on increasing the rear parking sensor volume? I had my module go pop when full of water. replaced with genuine like for like replacement but volume is now so low you can hardly hear it
( it was loud before it went bang), no option to turn it up on the centre console settings and didn't work trying to increase it by radio or steering wheel volume.
2010 5.0SC A/B FF any ideas guys?
Post #540722 15th Jan 2020 10:13pm
i moved my sounder to the lower part of the front drivers seat.. ... - .- -.
Post #540723 15th Jan 2020 10:21pm
