![]() | Home > In Car Electronics (L322) > Avin 4 install in 2003 |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Seeing as we lost all the pictures from Hylands excellent post, I did my own set and put them in a PDF for all to enjoy when I fitted the Avin 4 to my Range.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
To upload a pdf go into the gallery and your gallery, you can upload it there, then grab the link and make a post .
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
That looks a cracking piece of kit.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
Very interesting, and hopefully the answer to my prayers. Watching with interest. |
Unplug the quad lock from the BM54, plug new loom into quadlock. Done ! really simple- All speakers working including sub as you are not by-passing the DSP amp No7 - 2003 V8 Vogue |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 ![]() ![]() ![]() |
Lusen Member Since: 08 Apr 2020 Location: Skåne Posts: 2 ![]() ![]() ![]() |
Hi, all new here! Just ordered Avin Avant 4 for my 2003 L322 and found REwmer's guide, excellent write up. Although, I wonder if you pull the extension cable to the left in LHD cars as well?
Installed my unit this weekend. Pro tip: unpin the Quadlock connector when pulling the cable up to the head unit, it's just way to big to fit.
harra123 Member Since: 13 Dec 2020 Location: Nairne Posts: 9 ![]() ![]() ![]() |
Hi Rewmer, any chance you have a photo of the rear of the head unit & connections in the back of the car please. I am having issues with no sound although everything else works.
Hi Adam
Not sure Mark, I will retry this coming weekend, thank you |
Hi Mark, I also had a question that Avin are still to answer. When I connect the extension cable to the main harness from the DSP amplifier, do I connect anything to the exposed port on the amplifier itself? Your help would be greatly appreciated, than you, Adam |
