![]() | Home > In Car Electronics (L405) > Rear Dash Cam |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic27439.html
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
For the L322 it made some sense to mount it to the car roof as you shut the tailgate hard & the camera might fall off.
broncoupe Member Since: 21 Nov 2011 Location: bournemouth Posts: 70 ![]() |
Thanks for ideas but L405 is completely different
fin Member Since: 20 Oct 2010 Location: South East London Posts: 54 ![]() ![]() ![]() |
Due to way it is made the only way you can pull the cable through it to remove the rear spoiler which you can then drill a hole that cannot be seen and fish it through.
Like so. I though it was a good place as the parcel shelf does not lift up all the way like an L322 so will not hit it.
good solution that
SCL Member Since: 10 Jul 2017 Location: West Midlands Posts: 50 ![]() ![]() ![]() |
I had mine professionally fitted. They initially fitted it to the top of the rear window. I hated it as I could see the camera and cable in my rear view mirror. They relocated it to the bottom of the window and I now can’t see it.
I am sure they managed to run the cable through the left hand boot strut (as looking from the back of the car) and then down into the plastic panel in the bottom of the boot lid, then up though the plastic to the bottom of the window by making a discrete cut in the plastic. It did take longer to fit doing it this way. Hopefully the photos make more sense. The blurred arc line across the top of the photo showing a car behind me is the heating element. When playing a recording back you can’t see the arc. The black line in the bottom right corner is the power cable to the camera.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
is the DAB and FM radio reception still ok? |
Hi Stan
thanks steve.. |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 928 ![]() ![]() |
Stan
thanks chalky..i was curious cos there's a thread here somewhere where its said that the rear dashcam interferes with radio reception.. |
Thanks for the pictures will have a go and post results |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
You’re right Stan there was.
