Home > Technical (L405) > L405 hard suspension
hippo1966
United Kingdom 2014 Range Rover Vogue TDV6 Santorini Black
Hi any one experienced harsh ride on a 2013 vogue seems ok on smooth roads hit a bump man hole cover it seems to shake the front or car seems rock hard normal 20 wheels 35000 miles
Post #516008 20th May 2019 10:15pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I tend to agree that the ride quality isn't that great, however I'm running on 22 inch wheels which doesn't help. None the less it's not as smooth as my previous L322, but then again that did run on bigger tyres. I think the main concern with my car is it feels like it has 'wobbly legs' going over bumps, particularly on the near side. Front shock absorbers lower suspension arms and anti roll bar bushes have been replaced quite recently, but I suspect there may be other bushes in need of attention. In your case, the car has low miles for it's age, however degradation of rubber still occurs, although I don't think in should in that period of time. Additionally, because the cabin is so quiet, you do hear every bump, rattle and squeek. A four wheel alignment normally lets you know if anythings amiss so perhaps that might be your first course of action ? [/s]
Post #516449 24th May 2019 8:37pm
GraemeS
Australia
There are known problems with the 2013/2014 front suspension, from shocks that have leaked oil into the air-springs making the ride harsh to other components that allow the wheels to shimmy, for which several threads exist.
Post #516456 24th May 2019 9:37pm
