Home > Technical (L322) > Key won't turn in ignition |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 |
Does the steering lock disengage when you insert the key? If not, you may have the steering interlock issue as in the wiki entry
18th May 2019 7:00am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
If the car was ok before thebattery drain down it could be just needing a decent charge up to get back to normal.
18th May 2019 8:57am |
Blitz Member Since: 18 May 2019 Location: Billys Creek Posts: 33 |
Thanks finchi.
18th May 2019 9:06am |
It was fine before the tyre change episode. I was thinking it's either something to do with battery drain, or just a really weird coincidence. No wonder my husband didn't trust anyone to touch his baby! |
18th May 2019 9:07am |
I forgot to ask ... would 2 hours driving be enough to get the battery up to scratch? What about the 12.2v? Is that pretty standard? |
18th May 2019 9:08am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
12.2V indicates the battery is very low on charge, should be a minimum of 12.5-12.6V or even more after a run.
18th May 2019 9:27am |
I like the sound of that.
18th May 2019 9:39am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
When my 2004 322 had a flat battery the key would not turn, if I remember right the idea was that the car "thought" the battery had been disconnected and shut its systems down to protect itself. In that case charge was supplied from another vehicle via jump leads and a 'system reset' was required, ideally via a diagnostic tool, but in my case done by removing the leads from the battery and shorting them together (off the battery), called a 'hard reset' on here I think. You might want to search or get confirmation from a more knowledgeable person before attempting.
18th May 2019 10:34am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
12.5v at rest is about 50% charge. It should be enough to allow the key to turn and start the car but ithe battery is on its way out.
18th May 2019 10:47am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Just looking at the sequence of events here - the car was fine, then the battery flattened. Draining a lead acid battery too low can spell death for it.
18th May 2019 11:10am |
I connected the IID tool in the hope it would throw some light on the problem but unfortunately, it didn't show any fault codes. Was hoping it would bring up a fault that could be cleared, but no such luck. Thanks for the tip regarding the battery possibly not holding the charge. I looked up in my husband's folder to see when he got the new battery and being around 3 years ago, it wouldn't surprise me if it's had the dick. How long do batteries generally last? I remember someone saying about 2 years, though in my experience with Land Rovers, they usually last way longer. |
18th May 2019 2:53pm |
Yeah, that's what worried me - that 12.2v should be enough to start her. As the battery is towards the end of its used by date so to speak, I'm hoping that's the problem. I'll get a charger and see if it resurrects, but as you say, probably time to replace it anyway. Here's hoping it's an easy and cheap fix (relatively given the cost of a decent battery compared to a new steering column). |
18th May 2019 2:59pm |
Exactly my hopeful thoughts. Makes sense given the chain of events. Having said that, I was worried because my son's Range Rover Sport's battery went flat after he spent 4 hours cleaning it (yep ... ) leaving the stereo on the whole time. Once she was jumped, had no problems since. He'd had the Sport for about a year before this happened and have no idea how old the battery was when he purchased her. Not sure if it's the same set up as the Vogue though. May simply not be configured the same way. |
18th May 2019 3:05pm |
A massive thank you to all who replied and contributed to my post.
19th May 2019 2:03am |
