Home > Technical (L322) > P023D Fault Code Sorted.
Witzend
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hello All,
Just set off Out in vehicle this morning (2008 TDV8) got the dreaded boing and slowed to about 10 mph with engine fault warning but no mil lit up. Pulled over stopped engine, started back up running lumpy but got her home. Out with the IID tool which showed the above code, did a search on the forum and found the first place to start looking was the top turbo hoses, sure enough the top right hand hose had a split about an inch and a half long on the underside, I had been getting poor mileage also about 15/16 per gallon, So thanks to the IID Tool and this forum, Just ordered the said hose £46.00 Main Dealer,
So anyone thinking of getting the IID Tool, my advice is you can’t afford not to. A true friend is someone who worries about letting you down........ But never does.
Post #515402 15th May 2019 12:14pm
....and its a nice sunny day.. Thumbs Up
[good job Wink ]
Post #515404 15th May 2019 12:26pm
Witzend
Thank You Stan Thumbs Up A true friend is someone who worries about letting you down........ But never does.
Post #515405 15th May 2019 12:28pm
Andy
Genuine LR on eBay £34.
I still need to sort mine out. I get the same fault. Hoses are fine. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515419 15th May 2019 2:42pm
