Home > Technical (L322) > L322 drivers door
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
L322 drivers door
Hi people help needed hope his is in the right section my drivers door wont lock or unlock from
The remote or the switch inside the car and it wont lock when you go above 10mph or so but it works if i use the key to lock and unlock the doors is it just a simple as a new central locking module for that door or will it need NASA to program stuff thanks n advance
Post #515005 11th May 2019 8:06pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Most likely a new module needed but check the wiring to it first as it could be open circuit. No coding of a new module is required.
Post #515025 11th May 2019 10:47pm
Johnsd1v8
Thanks pal
Post #515051 12th May 2019 8:14am
