Home > Technical (L405) > Lots of warnings!
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Lots of warnings!
Driving long ... BONG!! Lots of warning lights and messages.
A quick check with the IID showed about 5 ECUs with warnings, but it would appear (to me, at least) that the ABS ECU is the guilty party, causing a failure of other systems relying on a speed signal.
I believe the first error is the one to blame - anyone seen anything like this before??? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #514351 5th May 2019 10:56am
Rosco
Spooky, I know it's daft but usually these things are battery related, have you checked that one? Thumbs Up
Post #514366 5th May 2019 12:56pm
Spooky
Turned out to be a corrupted VIN, which then caused the RCM (airbag system) to lose its sensor calibration. Shocked
Lots of patience by Patrick at GAP solved it - he really went Above & Beyond here! Thumbs Up Regards,
Mick
Post #514745 9th May 2019 9:04am
keving
Ireland 2015 Range Rover Vogue SE SDV8 Indus Silver
Hi I am having a similar problem with my 2015 l405 lots of warning lights on the dash .Switching off and on the ignition can clear them for a while but they will re-appear sometimes just 1 warning light or all of them .I have done a hard reset and this hasnt solved it.Im thinking of fitting a new battery as the battery in the car is the first day battery. Has anyone got any ideas
Post #525597 20th Aug 2019 8:53pm
