Home > Maintenance & Mods (L322) > Rear arch/ bumper repair DIY
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
So decided to have a go at repairing and painting the rear arch and a bumper scuff on the drive using spray cans
Bumper off left the mud guards on as I was working alone and wanted something to support the big heavy bumper a few 10 mm around the arches and 10 -8mm bolts at the back 5 up 5 down and off came the flimsy light bumper
So now the job begins
I needed to get rid of this
80 grit some filler and kurust I ended up here
It was then all flatted off and primed and masked off ready for paint
Base coat and clear added ending with this
Now came the bumper scuff
Flatted off primed painted and clear coated
Refitted everything and it just needs polished and waxed
All in all it's not perfect but I think it looks
a lot better and now everything is back in placed I may even do it again as one complete job and iron out the imperfections
[img]http://www.fullfatrr.com/gallery/albums/userpics/19882/normal_IMG_0494.JPG[/img
Post #515275 14th May 2019 7:33am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Nice one. Looks so much better now and hopefully you've stopped the rot spreading any further. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #515276 14th May 2019 8:10am
Henda
Cheers it just needed doing , was getting on my wick Thumbs Up
Post #515284 14th May 2019 9:16am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi nice job but I have had a similar issue with both rear arches that started to show signs of bubbling paint. This is a common issue with the L322 as they rot from the inside out due to a crap design the water and debris gets trapped under the inner wheel arch lip hence why they eventually rot from the inside out. I have had all the rot cut out of mine as this is the only way as I had mine rubbed down and treated on 2 occasions which only lasted a matter of months so complete waste of time and money. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #515298 14th May 2019 11:50am
Henda
Gave it a good clean behind there not as much crap as I thought , will see how long it lasts as I am looking for a mig welder so that could be my next adventure Thumbs Up
Post #515309 14th May 2019 2:55pm
