Home > Technical (L322) > How many fuse boxes, and where are they? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Third fuse box in the glove box. In at the back. John
2nd May 2019 12:36pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Behind a black cover that's hard to see Got - 2017 SDV8 Autobiography in Loire Blue
2nd May 2019 2:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
There is another (maxi fuses) on the firewall in the engine compartment (somewhere behind the battery) .
2nd May 2019 2:52pm |
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 |
So I assume the battery needs to come out to access it? |
2nd May 2019 6:49pm |
I would guess the "ignition relay" is in the big black box with 10 screws .
2nd May 2019 7:17pm |
"I would guess the "ignition relay" is in the big black box with 10 screws"
3rd May 2019 7:52am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I expect it to be in the passenger compartment fuse panel where it is in the RRS of the same era. |
3rd May 2019 8:57am |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 81 |
3rd May 2019 9:29am |
Looks like a different car to mine, and LHD.
7th May 2019 7:26am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
No Sir the diagram above is 2010-2012 (assuming it's L322)-- you have the front fuse box in your picture Current: 2011 FFRR Vogue SE 4.4 TDV8
7th May 2019 7:54am |
To remove glovebox .
7th May 2019 12:53pm |
