![]() | Home > Technical (L405) > Fronts suspension noise - how to recreate it? |
MONT322 Member Since: 22 Jan 2017 Location: Surrey Posts: 33 ![]() ![]() ![]() |
Remove the golf clubs from the boot when you visit the Master Tech |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
The cabin of an L405 is so quiet you can hear the slightest noise, even the sound of your own movement such as clothing etc. Personally, I turn up the sound system ! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
I was thinking of getting a 405 but if you can hear the sound of your own movements - I'd better start drinking less first |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Fleagle, ask the fitted to check the bolt in the valve block that fouls the fuel pipe! Its quite a well known noise |
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 ![]() ![]() ![]() |
The technical bulletin itself has some good examples of things that cause the noise- have you tried all of those? |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
"The technical bulletin itself has some good examples of things that cause the noise- have you tried all of those?"
Whoops, sorry. I’ll be having similar discussions with my dealer shortly |
My dealership are saying its the ARC valve block that needs replacing. - warranty have refused to pay. |
yeah - that's already in the 00557 tech bulletin (now upto version 10 !!) - they claim it's not that. |
To close this off if anyone else suffers...
