Home > Maintenance & Mods (L322) > Boost Leak / Loud Spooling / P0046 Fault Code on 2004 TD6 |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
Recheck all connections and the connectors on the intercooler, I had two come hose’s come loose 1) from the intercooler, the snap clip not securely connected. 2) hose connecting to the turbo jubilee clip had come loose and sucking in air. 2004 Autobiography TD6 Java Black |
20th Apr 2019 11:56am |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 929 |
I am now getting P0046 as a fault. This only happens if it floor it. Would a boost leak potentially come from this if I have accidentally pulled a vacuum pipe off? Don’t know if I have or not, no idea where this device is either
21st Apr 2019 4:03am |
For future reference for anyone else who didn't get an answer to this question, my leak was from a braded vacuum hose, so the split was hidden. So if all your other main hoses are definitely tight, then check the vaccum hoses, or better yet, just replace them all. I am now in the process of replacing them all gradually. |
24th Apr 2019 8:39am |
