Home > Technical (L322) > 12v cool box
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
12v cool box
If I plug a 12v cool box into the boot and go off for a few hours to take the kids out will it drain my battery down to the point the car won’t start?
Just so you have all info in helping me answer battery is only 2 weeks old and it will be a good 25 min drive. Wrote stopping the car. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #512627 19th Apr 2019 9:12pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I thought when I tested the rear socket in my 2011 L322 last year that I decided it turned itself off once the car was locked, or very soon thereafter?
When I've had a camping fridge in mine, I still unplug it if not driving just to make sure it doesn't drain anything! I forget the specs on my fridge, but it is a reasonable drain, and knowing how sensitive these machines are to a decent voltage, I decided to just play it safe.
Post #512628 19th Apr 2019 9:24pm
dazza1983
Thanks buddy.
Hopefully a cool box will keep things cold for a few hours anyway. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #512629 19th Apr 2019 9:28pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Bag of ice in the bottom make sure it's in a sealed Polly bag keeps frozen for a couple of days .Keeps everything nice and cold without leaving it plugged in.
Post #512633 19th Apr 2019 11:40pm
Baltic Blue
If you are taking bottled water for drinks.
Pour an inch out of each, then freeze them at home before packing them in cool box. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #512640 20th Apr 2019 7:16am
GGDR
I like your style Mike. Thumbs Up Thumbs Up
. Cheers, Greg
Post #512643 20th Apr 2019 7:49am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Everything shuts down including the 12v socket tried to use an air pump and unless I kept the car running it would shut off.
Post #512644 20th Apr 2019 7:57am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Install a 2nd battery in the right side below the floor, where detachable hitch lives, change your engine battery terminals to quick release, then in future simply detach neg terminal on starter batt and run anything off the aux batt for ages, confidant when you re connect the starter batt it's still fully charged. Car is never totally with out power so no settings, are lost. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #512793 21st Apr 2019 11:37pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My boot socket stays live all the time (2006 MY 4.2) I use it to connect the C-Tek when I'm away.
I have a cool box which I disconnect whenever the engine is not running. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #512794 22nd Apr 2019 4:18am
mjdronfield
On the later cars the sockets shut off. I made the mistake of spending best part of £300 on a coolbox with a lead that turns it off if battery gets low, but can’t use it as I wanted.
Think you can make one of the sockets live with a desire, but I’m not an electrician. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #512797 22nd Apr 2019 7:28am
Rob99
There are some permanent live connections in the rear fuse box which you could use. You should easily be able to rewire the boot 12v socket to use one of them. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #512800 22nd Apr 2019 8:24am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
don't know which cool box you have but the halfords 40 litre cool box takes 3.5amps and a good, fully charged range rover battery would run that for about 15 hours and still only be half discharged.
when you fitted the new battery, did you fit the correct type (AGM / lead acid) or tell the computer otherwise because that would be consistent with your problem.
Post #512891 23rd Apr 2019 9:11am
Agree with the above but to be absolutely sure you can still get into the car if the second battery voltage does happen to drop to a level the electric locking won't work, check the manual key locking / unlocking still works on the drivers door. Thumbs Up
Post #512892 23rd Apr 2019 9:24am
