Home > Technical (L322) > Uneven wear rear tyres
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi all,
Noticed yesterday that the outside edge of the rear tyres, on both sides, have worn quite badly. All 4 tyres were new about 4 months ago, good quality, and the fronts are still like new. All tyres are always correctly inflated and checked at least weekly.
First thought was that the rear bushes were probably done, but a quick call with a local indy (not specialist, but trusted) suggested that since both rears had worn in the same pattern at the same speed, then it's unlikely to be the bushes.
Is that a fair assessment, or should this still be the first port of call? What else could be causing the issue?
TIA
Post #509767 25th Mar 2019 12:04pm
Rob99
Find a good 4 wheel alignment specialist (with Hunter equipment) and get it checked and adjusted.
At least then you've eliminated another cause. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #509768 25th Mar 2019 12:13pm
DrRob
Get a proper 4 wheel alignment done. It might be way out. Use a place that can put car into tight tolerance mode. If they don't know what that is then don’t use them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #509770 25th Mar 2019 12:25pm
DrRob
www.alignmycar.co.uk is a good start Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #509771 25th Mar 2019 12:25pm
Pawl
Get it jacked up with the wheel off to check the suspension bushes.
The check costs nothing & should quickly identify if bushes have worn .
How many miles has the car done & how many of those with you ? Paul,
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Post #509815 25th Mar 2019 5:47pm
Um, it is quite likely that both sets of rear suspension bushes (possibly including the toe arm) are shot and thus causing the wear (just as likely as the wheel alignment being out by the same amount on both sides) .
Post #509818 25th Mar 2019 5:56pm
gj88
Thanks all,
Joe, you hit upon why I asked the question, I couldn't see why it would be less likely than anything else that was effecting both sides. Bushes seemed most likely to me, but it's booked in on Friday to get it on the ramp and have a look, will check the bushes and get it aligned, hopefully one of the two will sort it.
In answer to other questions, just ticked over 100k, about 10k miles in my ownership
Post #509821 25th Mar 2019 6:13pm
gj88
Just a quick update to complete the thread, been into the mechanics today and both lower hub bushes/rose joints are knackered, and one control arm has seen better days. Booked in to do the lot and a 4 wheel alignment, £550.
Thanks for the pointers Thumbs Up
Post #510246 29th Mar 2019 6:04pm
PIMCO
Norway
So the lower balljoints were busted, but the uppers were fine?
Post #512043 14th Apr 2019 11:49am
