Home > Technical (L322) > Fault Code P0480-13 (2F)
Weegie
Getting fault code "P0480-13 (2F) Fan 1 control circuit - general electrical failure - circuit open".
Search doesn't turn up anything of help.
Looking for confirmation that Fan 1 is the viscous fan and that the relay is in the box in the engine bay? I know I will need to check the connections and feed.
I am a little confused (what's new Embarassed ) as any references in a search turn up references to the AC fan and replacing the FSR which doesn't seem to the problem.
Any pointers would be appreciated. Ta in advance. John
GAP iiD BT
Post #555365 26th May 2020 2:59pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
From memory you should have a 3 or 4 pin connector, top right of the rad as you look at it from the front of the car, I have mine disconnected as I have a viscous fan fault. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #555370 26th May 2020 3:36pm
Weegie
Thanks. Will have a look. Thumbs Up John
GAP iiD BT
Post #555374 26th May 2020 3:57pm
