Home > Technical (L405) > Suspension Fault L405 2013-2017??
knwatkins
The bulletin does not, you are correct. However there are some items in there that do not apply to vehicles with the TDV6 engine, hence the reason for my question.
Good luck with your dealer Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #573769 22nd Nov 2020 10:10pm
Daniel
2005 Range Rover HSE Td6 Giverny Green
Thank you.
The noise only becomes apparent after first driving on a rough road (off road conditions on driveway (10° side slope, roots and rocks mostly affecting one front wheel at a time only).
The selling dealer (1,000 km from home) has promised in writing to do whatever it takes to fix the issue.
The servicing dealer (150 km away from home in opposite direction) has told me that there is no detectable noise and no visible worn components.
When I brought the bulletin to the service manager, he told me he will not fix my car.
Hence the issue has been brought to Jaguar Land Rover CRC.
The initial response from CRC is that the servicing dealer must fix it.
I advised that under the circumstances, I would rather drive 250 km to another dealer to have it fixed.
I will advise the outcome.
Post #573773 22nd Nov 2020 10:50pm
