Home > In Car Electronics (L322) > L322 2004 DSP disappeared FIXED |
MadL322 Member Since: 09 Oct 2018 Location: Yeovil Posts: 108 |
If the DSP has failed, have one for sale at the moment if you're in need |
25th Mar 2019 9:10pm |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 |
Will keep it in mind Thanks,
25th Mar 2019 10:28pm |
if you need anything else, I have all the audio kit from the rear, took it out at the weekend in prep for a new head unit so all parts available. |
25th Mar 2019 10:34pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Open up the DSP, mine had funk on the inside, and a disconnected pin! Current: 2011 FFRR Vogue SE 4.4 TDV8
26th Mar 2019 8:02am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
It will be grey in the menu until it identifies itself on the ibus, then it will be white again.
26th Mar 2019 9:12am |
Thanks mjdronfield you pointed me in the right direction.
26th Mar 2019 5:07pm |
Nice one.
26th Mar 2019 5:09pm |
