Home > Technical (L405) > Interior rattle L405
CJB1000
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
Hi guys,
Does anyone have a fix for an annoying rattle coming from the front cup holder area?
It’s not coming from the sliding cover, but seems to be from to rigid plastic cup holder moulding (with or without the rubber inserts)
The whole area of the moulding appears to be vibrating and can’t see any fixings.
Any help gratefully received.
Thanks.
CJ
Post #509671 24th Mar 2019 9:53am
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Mine seems pretty solid so I would expect yours has come away from it's fixings. I don't have a workshop manual but would guess it's put together in a very similar way to most LR products. Ie snap together. I'd apply some pressure to it to see if it snaps into place but take it easy. I don't accept the costs for any damage caused btw. Thumbs Up
Post #509749 25th Mar 2019 7:10am
CJB1000
Checked - all fixings seem secure - the plastic just vibrates!
Don’t want to start dismantling the centre console so if no one has any better ideas, I will try and pack the sides with good old fur tape!!
C.
Post #512198 15th Apr 2019 10:40pm
Badger
United Kingdom 2018 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Are you SURE the rattle is coming from there?
Reason for asking is that I had a rattle that seemed to be in that lower central area, but it was actually caused by the passenger sunvisor being unclipped from its hinge (so you can pivot it across to the side window. This is why they give you a second smaller visor, in case you are ever driving on a planet with two suns! FYI).
HTH
Post #512903 23rd Apr 2019 10:47am
CJB1000
Thanks Badger - No my visor is securely docked and ready for a trip to outer space!
STILL have my annoying vibration however.
Definitely coming from the cup holder moulding.
If I tap on the hard plastic surround, it vibrates, giving a rattle when on the move - very annoying!,
Struggled to get into the gap to pack it - has anyone got any other ideas please?
CJ
Post #512975 23rd Apr 2019 9:29pm
The cup holders just pop out and there is a panel that gets you to the emergency gearbox pull... Tried any of those yet sir?
Post #512977 23rd Apr 2019 10:24pm
CJB1000
Hi Craig,
Once the rubber cup holder/inserts are removed, mine only has a shaped hard plastic “box”. This is what rattles.
There are no visible fixings or openings in this area.
Please kindly advise.
Thanks.
CJ
Post #512984 24th Apr 2019 5:57am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Funnily, I often got a rattle and was also the larger passenger sunvisor not clicked into place properly after use (drivers side never an issue) . Looks like the base cup holder part is fixed in from underneath I think...
 Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #513146 25th Apr 2019 12:46pm
CJB1000
Thanks for the image.
Definitely NOT sunvisor issue as, both passenger visors are securely clipped in.
Looks like I’m going to have to try and pack in between the two plastic pieces in that case!
CJ
Post #513372 27th Apr 2019 12:13pm
