Home > General (L405) > Land Rover Approved 165 point check. |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
The check sheet just gets ticked and filled with lies.
18th Mar 2019 8:21pm |
So Member Since: 25 Sep 2017 Location: UK Posts: 16 |
To be honest the dealership has been a bit tricky so far.
18th Mar 2019 9:25pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
18th Mar 2019 9:36pm |
Unless I am missing something the minimum disc thickness is not in that thread.
18th Mar 2019 9:51pm |
Is about allI can see - what the wear limit is is anyones guess...... |
18th Mar 2019 9:59pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Depending on which variant you have, new discs are either 20 or 25mm thick and both have a 3mm wear limit
18th Mar 2019 11:26pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Sizes/thickness's are stamped into your disc bells... Remaining thickness can then easily be measured |
19th Mar 2019 12:30am |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 83 |
I too thought that the disc lipping on my 27,000 mile L405 was excessive, however in talking to two (admittedly L-R) garages before I bought the car (from another L-R garage) they told me that there was plenty of 'meat' left on the disc, and that a new disc only starts 2mm thicker than the minimum thickness (stamped around the hub area of the disc) and that this wear-rate would equate to 50,000 miles which is normal.
21st Mar 2019 10:36am |
