Home > Technical (L322) > Changing front crosslink valve-air suspension
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Hi All,
08MY TDV8...mechanic has looked at why air suspension is playing up. He reflashed the RLM(no idea either) and now the car won’t go from standard setting but does through up a fault code for the front crosslink valve.
Has anyone changed one, know where it is and whether there is good chance I’ll blow my head off with many psi of air pressure?
Any top tips would be much appreciated.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #508927 16th Mar 2019 4:41pm
The front cross link valve is behind the wheel arch liner on the Front Right
You don't have to remove the entire wheel arch liner to access it, just peel it forwards from the back, undoing the nuts as required.
Jack the car up and support on axle stands
Best to disable the EAS / disconnect the battery, then gently undo the pipe nuts on the valve slowly releasing the pressure
Could be that a dismantle and good clean up might resolve, if the valve gets any water ingress it can build up corrosion and seize a valve or two.
You may not thank your "mechanic" for reflashing the RLM..... .
Post #508930 16th Mar 2019 4:55pm
EDWARD757
Thanks Joe. What are the possible consequences with the reflash? '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #508958 17th Mar 2019 12:32am
um...
If it ain't broke... now I know it was broke, but sounds even more broke now ... .
Post #508959 17th Mar 2019 12:45am
EDWARD757
Lol, that’s almost a quote of what I said to them when I picked it up.... '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #508965 17th Mar 2019 8:03am
Not the same valve, but some images of disassembly of the reservoir one, i have seen others with serious "crud" inside
https://www.fullfatrr.com/forum/topic27157.html .
Post #508970 17th Mar 2019 9:39am
