Home > General > MPG on a TDV8 3.6
Page 4 of 4 <1234
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
That’s interesting. Everything I’ve read on here points to the 4.4 being far better on fuel. 2009 pre-facelift 3.6 TDV8.
Post #697724 9th Aug 2024 4:58pm
Andygriff73
I got roughly between 520-560 miles per tank in the 4.4 but that was on shell v power. The egr has been blanked on the 3.6 so I don’t know whether that is the difference. The 4.4 was higher mileage than the 3.6 but both turbos had been changed in the 4.4 again no bills for turbos having been replaced on the 3.6.
Post #697778 10th Aug 2024 12:58pm
KitTheRam
Does blocking the EGR lead to a little less mpg? Guessing the map the cars given after has the most effect.
For what it’s worth I only put 60L in at a time (it’s not driven that often), I personally really notice the weight when driving with a full tank. 2009 pre-facelift 3.6 TDV8.
Post #697783 10th Aug 2024 3:21pm
JayGee
It's better but not 'far better' with taller gearing from the 8 speed likley being the main reason. If Andygriff73 was only getting 550 mile sper tank it suggests there was an issue with his car. Unless the EGR valves on a 3.6 were leaking it's unlikley better MPG will result from blanking or deleteing them. Main reason is to protect the turbo's and engine from destruction if they fail. A sticky EGR valve that doesn't shut fast enough when applying power will blunt throttle response and feel uneven in performance. 2012 TDV8 Vogue (L322)
Post #697813 11th Aug 2024 9:10am
Page 4 of 4 <1234
