Home > Technical (L322) > [Solved] L322 Brakes Lights on with ignition off |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I had an issue a while back when the LCM refused to communicate. Waited a while, drove the car a bit, then LCM came back on line.
1st Mar 2019 5:12pm |
Qahmed95 Member Since: 28 Jan 2017 Location: Birmingham Posts: 27 |
Trailer module was in place from the start, after a response from another forum I understand that Fuse 2 supplies the rear fuse box.
1st Mar 2019 8:53pm |
So everything seems to be back to normal, I checked the wheel well and apart from a little surface rust on the boot floor, no corrosion on any plugs and all wires looked good.
2nd Mar 2019 12:49pm |
