Home > Maintenance & Mods (L322) > Static bending bulbs melted my lights
Alz
United Kingdom 2007 Range Rover HSE TDV8 Barolo Black
I have a Range Rover tdv8 2007 hse and it’s got a 2010 upgrade OME led lights I noticed that my adaptive light is in the dash I cheeked lights to find both bulbs have melted the Crome bulb holds one bulb was still working the other bulbs seems to have no power going to it the bulbs works as I’ve tried it in other side the bulbs sockets are totally melted don’t think there repairable if I buy new lights will this happen again
Post #506632 27th Feb 2019 10:16pm
not sure what you actually mean..can you post pics maybe..
saying that if its had a facelift then the wiring can be at fault ..did you have the work done ?? if so i'd take it back to the peeps that done the job..
Post #506658 28th Feb 2019 11:51am
Alz
No it was already upgraded when I had the car
Post #506701 28th Feb 2019 3:20pm
then its an auto electrician or someone who does facelifts...
if you're near Gloucester , theres a forum member that knows everything about conversions and he resides in a place called Cam...names craig.
Post #506710 28th Feb 2019 4:18pm
Alz
I have just read the white side lights, other people have had the same problem but it dose not say why this happens I’ve had a mate test the power going in to the lights and he is saying it’s the correct voltage so I’m now lost It dose say a lot of people remove the bulbs to stop this happening I had H8LL 35 watt bulbs in before so I think I’m going to change the bulbs to led and if I can’t repair the damaged bulbs holders I might just leave the bulbs out and live with adaptive light on the dash . I will try put some photos on
Post #506723 28th Feb 2019 5:23pm
Alz
Not very good photos but I think you can see the plastic holders have melted
Post #506724 28th Feb 2019 5:27pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Are these the cornering lights? If so, they're not meant to be on all the time. I wonder if that's what's caused the heat problem? 2010 4.4 TDV8 Vogue SE
Post #506788 1st Mar 2019 8:21am
Alz
Yes they are there on soon as I turn the key
Post #506907 1st Mar 2019 5:55pm
Alz
I now have both cornering lights working if I have cornering static bending light will I have adaptive head lights also because I’m unsure my car is Range Rover td8 hse LR20 how would I be able to tell if I have adaptive lights because there isn’t two ballasts on the lights and I’m thinking have the wrong lights been fitted to car when the up grade was done because I have the adaptive light flashing on the dashboard but don’t have two ballast on the bottom of the lights
Sorry not very good at this .
Post #506966 2nd Mar 2019 10:39am
firstly, you say you have a 2007 HSE variant which doesnt exist....do you have a sport??
secondly , did you have adaptive headlights before the facelift??
thirdly , if you have adaptive light now then the cornering lights only come on when on when turning the steering wheel left or right...
Post #506978 2nd Mar 2019 11:22am
Alz
I have range rover sport hse 2007 I have just called Land Rover and they have said my car is listed having static bending and adaptive head lights as I only have 1 ballast on the bottom of the head lights I think the wrong lights have been fitted before purchase the car seems the lights I have are ome led style head light nine afs if I have got that right when afs should be fitted
Post #506988 2nd Mar 2019 12:11pm
this forum is for the larger range rover and there is a sport forum where you might get a more specific answer to your problem..
http://www.rrsport.co.uk/forum/index.php?s...713ee8379e
Post #507013 2nd Mar 2019 3:54pm
