Home > Duckworth Parts > 2012 L322 LHD Headlights
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hi Dan,
Can you provide a price for a set of LHD / European headlights for a 2012 L322 - standard Xenons?
I’m looking to register my RHD car in Spain and the lights will need changing to LHD spec.
Thanks
Post #506372 25th Feb 2019 7:53pm
ilard
Isn’t there a mechanical lever behind the rear dome on each headlight to switch it to LHD countries?
Post #506405 25th Feb 2019 10:42pm
TDV8_Tommy
Each headlamp unit has a mechanical lever which simply 'flattens' the beam so you don't dazzle oncoming traffic - which is what I'm currently doing.
In order to be matriculated in Spain and to pass its ITV (MOT) the lights need to 'throw' the pattern up to the right-hand side which flattening or levelling off won't do hence a fail and new lamps needed Sad
Post #506421 26th Feb 2019 6:56am
dingg1
try putting it through the test first with the lever flattening the beam and the lamps adjusted to point more towards the right.
most have managed to get a pass without the expense of changing the headlights.
I'm going through the same scenario in portugal in a few weeks time
good luck
Post #506427 26th Feb 2019 8:27am
TDV8_Tommy
Thanks, Dingg1 - certainly worth the cost of the test vs €sss on new lights.
I had a quote for importing/registering the car this morning....€4200ish before any lights....ouch. I think at that cost I'll just run her home every 6 months instead and hit the reset on the time allowed in the country, get her serviced and at the same time stock up on HP sauce and Paxo!
Post #506428 26th Feb 2019 8:32am
dingg1
is that cost using an agent?
cost here is about 800e using an agent to grease the wheels as it were , diy with all the form filling to do cost about 300e for fees inc declaration, test (mot) etc
got to get a sworn declaration from the embassy to start the process off though.
Post #506429 26th Feb 2019 8:40am
TDV8_Tommy
Yes, using an agent - their fee is about €600, the rest is the tax on the value of the car + Co2 emissions.
You can do it DIY but there is so much red-tape and bureaucracy most people balls-it-up.
Even our 15-year-old Volvo cost €1200 to matriculate.
Post #506432 26th Feb 2019 9:46am
dingg1
Road tax I guess you mean?
900e a year on mine apparently , no discount on lpg either Crying or Very sad
Post #506434 26th Feb 2019 10:14am
TDV8_Tommy
The road is very reasonable, less than half that of the UK.
Its the initial import tax that's the killer.
Post #506440 26th Feb 2019 10:49am
duckworthparts
Site Sponsor
will most likely work out cheaper returning to the UK
Genuine LR headlamp £1050.00inc vat
or other option is OEM Marelli units at £720.00inc vat each You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #506443 26th Feb 2019 11:03am
TDV8_Tommy
Thanks, Dan, inclined to agree with you - simply not worth the cost. All to essentially have a different number plate!
Post #506447 26th Feb 2019 11:21am
dingg1
Tommy
If you satisfy all conditions car can be imported free of any tax here in portugal , spain should be the same
Post #506455 26th Feb 2019 12:36pm
dingg1
Just had mine tested for matriculation in portugal and all passed , headlights needed some adjustment but done by the tester (rhd lights still fitted but lever to europe setting) Very Happy
Post #509431 21st Mar 2019 12:15pm
TDV8_Tommy
Hi, I'd love my to pass its matriculation but my mechanic advised the lights don't 'throw up' enough light, you can see how flat they are with the Tourist mode enabled. Well done though!
 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #509450 21st Mar 2019 2:42pm
Baltic Blue
It’s a dead easy (and toll free) trip down from Alicante to Faro.
Might be an alternative solution to re- register it in Portugal and visit when the annual “MOT” is due ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #509454 21st Mar 2019 2:59pm
