Home > In Car Electronics (L322) > Nokia BT module
elblanco
Ireland 2007 Range Rover Vogue SE TDV8 Santorini Black
m@ttsFF wrote:
Worth noting if you have an IID tool .
thanks, are these things super expensive? I have an iCarsoft CR Pro, but doubt this does what IID tool does?
Post #526245 27th Aug 2019 1:52pm
Danwilderspin
Got mine in and working but it’s a little crackly any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #527298 7th Sep 2019 9:25am
chrisv
Bump.
The Nokia BT module on mine has been, surprise surprise, bypassed. Opening it up shows that there's a blown resister(?) and a bent input pin. I am assuming it is not repairable.
However before I get one of these upgrade kits off ebay (https://www.ebay.co.uk/itm/194108649348?ha...SwjTZglQ1X), I need to repair the MOST cable.
The male connector casing has been removed and the two ends joined by a small piece of black tubing.
Another thread on here implied that I can get the casing.
Anyone know where I can get the male connector casing from?
Thanks.
Update: Sorted a connector from ebay along with a bypass loop. This way I can rebuild the connector and still bypass it until I get the replacement in. --
Current: 2006 3.6 TDV8 Vogue
Previous: 2007 V8 HSE RRS, Disco TDi x 2
Post #593880 11th May 2021 2:58pm
