![]() | Home > Technical (L322) > 3.6 TDV8 Oil Leak |
Tom Member Since: 23 Feb 2019 Location: Midlands Posts: 9 ![]() ![]() |
If you mean fuel injector, you'd be passing carbon past a seal, not oil. Google Mercedes CDI black death for ideas when injector seals fail. Can you get any photos and do you have access to TOPIx? |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Hi Tom,
Finally got some time to work on this, it’s had a new camshaft cover gasket and all is well |
Few months on and its still dry |
jasont3860 Member Since: 10 Jul 2020 Location: Western Australia Posts: 1 ![]() ![]() ![]() |
Hi TJH1985
Hi Jason,
mickd Member Since: 26 Jul 2020 Location: Brisbane, Australia Posts: 5 ![]() ![]() |
Hi Tom, I'm guessing you sold your TDV8 for the next model in the line. Just following your thread as I seem to have the same issue with oil leakage around the base of injectors. Mine is mostly on drivers side. I'm curious whether you replaced the hard fuel lines (high pressure), as they say in the workshop manual to discard them. |
Yeah sadly/stupidly sold it, miss is allot!
Thanks for replying.
Depends on what’s LH/RH but we did the RH bank looking at the car and had to take the engine mount bolt out in order to jack it enough to remove the last injector. If I remember the LH looked like it needed the air conditioning lines splitting or something similar and as it was bone dry I though it better not to disturb and potentially cause other issues than dive in.
Dublin_d Member Since: 17 Feb 2021 Location: Dublin Posts: 1 ![]() ![]() |
Hi do you have part number for injector seals |
Andy79 Member Since: 12 Oct 2021 Location: North Yorkshire Posts: 13 ![]() ![]() ![]() |
Hi ,
The hardest part is getting the rear injector out, the L/H side is the easier of the two due to better access to the engine mount. If you've not done one before, start early! Other than the gaskets, you'll need injector seals (Bosch part number F00VC17503 - about £12 for a bag of ten) and some brake cleaner and an injector port brush or similar for cleaning the injector ports. Ideally new injector bolts, you can re-use the clamps and HP pipes, the injectors should be put back in the same cylinders they came from. Be careful removing & refitting the injector leak-off line, it can get brittle and I'd suggest a new set of Viton seals - I don't have a part number and they're not available from LR but I think there's a Ford or PSA part available - oh, most important, don't drop the leak-off line clips when you take them out!.
Hi Phoenix,
