Home > Technical (L322) > Emerging Vanos issues? |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
19th Feb 2019 11:15am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Check for any codes being logged (with something like an IIDTool) and go from there. |
19th Feb 2019 5:40pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I'll be interested to see what the outcome is & how you get on eventually.
19th Feb 2019 6:00pm |
jk3528 Member Since: 28 Sep 2018 Location: stoke on trent Posts: 46 |
Have you done the chain and guide’s they need doing before any rattle gets worse just done the ones on mine engine is now fine just need sort the electrical faults with the I-bus |
19th Feb 2019 6:59pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If you have Engine light you should have codes which will help. Vanos doesn’t usually have a big effect on performance. I would be concerned that you may have blocked cats which can really harm your engine although if a restart fixes it temporarily it could be many things so codes again.
19th Feb 2019 8:05pm |
Thanx Guys. Some great info and advice there. I've plugged in an OBDII bluetooth unit in and got these codes out:
19th Feb 2019 8:48pm |
ideally you need a diagnostic tool to clear all the faults and then see what comes back when you drive it, some of those codes could have been there for years. |
19th Feb 2019 10:56pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 900 |
I still say clean the electro valves first had a little rattle on an engine we rebuilt cleaned out the val es no more rattle and as chicken says the vanis has little effect on performance |
20th Feb 2019 12:11am |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
Engine light flashing is a misfire, I'd look at the easy stuff first before going to VANOS. Oil on plugs, blocked cat, PCV issues, vacuum leak can all cause a misfire or rough running.
20th Feb 2019 8:54am |
